[gdal-dev] AsGeoJSON with SQLite dialect returns an empty string
Even Rouault even.rouault at spatialys.com
Thu Mar 28 08:31:49 PDT 2019
On jeudi 28 mars 2019 15:01:20 CET Rahkonen Jukka (MML) wrote:
> Hi,
> I noticed this question
> https://gis.stackexchange.com/questions/316776/ogr2ogr-fails-with-no-such-t
> able and tried to study that odd shapefile by repeating the test with GDAL
> 2.4.0 from OSGeo4W and there happens something with ST_AsGeoJSON that I do
> not understand.
Jukka,
This is a Spatialite bug specific of ST_AsGeoJSON + Geopackage geometry blobs.
I've sent a patch to the Spatialite maintainer to fix it.
Other workarounds:
- for no precision loss at all, you can also do:
AsGeoJSON(ST_GeomFromWKT(AsBinary(geom)))
- or you can also use -dialect indirect_sqlite that will go through the slower
indirection of using a virtual sqlite table with spatialite geometries.
Even
http://www.spatialys.com
