[gdal-dev] Compression not applying when updating/exiting GeoTiff file in GDAL?
taylorday.assimila at gmail.com taylorday.assimila at gmail.com
Fri Mar 29 03:34:49 PDT 2019
Thanks for your quick reply Even, you've confirmed my thoughts.
My reason for having all bands in one file was to reduce I/O operations so
that obtaining a time series (one pixel from each band) is super quick. We
currently have a system where each time slice is a separate GeoTiff and the
bottleneck is opening and closing each file (particularly when iterating
over 10 years' worth of hourly data - 87600 files). We also wanted to
include compression to create cloud-optimized GeoTiffs (COGs) to serve using
`vsicurl` etc.
If I run my `gdal_merge` command with -co INTERLEAVE=BAND as you suggest, I
get a file with 8760 bands (with BIL) and then updating a single band is
almost instant (no rewriting everything as only the new band needs to be
rewritten)- so thank you! It seems that this was what I was missing and in
the end was a very simple solution!
Taylor
-----Original Message-----
Sent: 29 March 2019 09:20
To: gdal-dev at lists.osgeo.org
Cc: taylorday.assimila at gmail.com
Subject: Re: [gdal-dev] Compression not applying when updating/exiting
On vendredi 29 mars 2019 09:02:08 CET taylorday.assimila at gmail.com wrote:
> Hi all,
> I posted this question on GIS SE (link
> <https://gis.stackexchange.com/questions/317009/compression-not-applyi
> ng-whe
> n-updating-exiting-geotiff-file-in-gdal?noredirect=1#comment515654_317
> 009>
> ) but have not had any luck, so was wondering if anyone here could help.
> I have a `GeoTiff` file with dimensions 300 x 300 and 8760 bands
> (hourly for one full year). I am testing some code that opens the
> file, updates ONE band and exits - but I am finding that the file size
> almost doubles when I exit the file, despite the new band being the
> same data type etc. Code is as follows:
> I am creating the `GeoTiff` file using the following creation options
> using many singular `GeoTiff` files:
>     gdal_merge.py -separate -co BIGTIFF=YES -co COMPRESS=DEFLATE -co
> PREDICTOR=1 -co TILED=YES -co BLOCKXSIZE=64 -co BLOCKYSIZE=64 -o
> block64.tif *.tif
This will create a geotiff file with default pixel-interleaving. If you want
to update bands separately, you might prefer adding -co INTERLEAVE=BAND, so
that TIFF tiles only contain data for one single band. With the default
INTERLEAVE=PIXEL, when you rewrite a single band, you must be aware that you
end up rewriting the whole file under the hood.
Which explains the dramatic effect you see on file size currently. One thing
to have in mind is that the libtiff library used by GDAL has no "garbage
collection", so when using compression, if the updated compressed data
occupies a larger space than the previous one, the old space is lost and the
new compressed data is written at the end of the file.
I don't know the datatype you use, but a uncompressed file could also be an
option and won't have issues with growing size when being updated. This
would be at worst a 7.1 GB file for 64-bit floating point data type.
Even
Spatialys - Geospatial professional services http://www.spatialys.com
