[gdal-dev] Should the next version (previously 2.5) be called GDAL 3.0 ?
Kurt Schwehr schwehr at gmail.com
Wed May 1 13:29:46 PDT 2019
+1 Calling it 3.0 would definitely help non-developers understand how
different/better things are.
On Wed, May 1, 2019 at 12:09 PM Frank Warmerdam <warmerdam at pobox.com> wrote:
> Even,
> I think calling it 3.0 would be reasonable.
> Best regards,
> Frank
> On Wed, May 1, 2019 at 11:56 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Hi,
>> As a feedback from the previous motion, it appears that GDAL 3.0 would
>> probably better reflect the API & behaviour changes that have been done,
>> and
>> be in accordance with our HOWTO-RELEASE procedure and semantic
>> versionning
>> rules.
>> I'm OK with that change.
>> If we decide for that, the plan would probably be:
>> - change in docs & other materials the references to 2.5 to 3.0
>> - create a release/3.0 branch from the HEAD of release/2.5
>> - abandon release/2.5 branch (that is: backports would be done in
>> release/3.0,
>> and for longer support in release/2.4 when appropriate)
>> - issue a 3.0.0RC1 from that
>> - call master 3.1dev
>> Thoughts ?
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows |
> and watch the world go round - Rush    | Geospatial Software Developer
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190501/8dd2c69f/attachment.html>
