[gdal-dev] gdal_contour: 2.2.4 vs. 2.4.1
Seonghyeon Hahn SEHAH at vestas.com
Tue May 14 22:53:30 PDT 2019
Hello,
We've been using gdal v2.2.4 for a while. In particular, we've been frequently using the "gdal_contour" command
for raster-to-vector conversion from the Golden Software ASCII Grid (GSAG) into the WAsP .map format
in the following way:
% gdal_contour ./input.grd ./output.map -i 10.0 -f WAsP
This has been working fine with gdal2.2.4, but recently upgraded gdal2.4.1 doesn't seem to work. If I run it
in the verbose mode by setting CPL_DEBUG=ON, it writes the following error messages:
% gdal_contour ./input.grd ./output.map -i 10.0 -f WAsP --config CPL_DEBUG ON
GDAL: GDALOpen(./input.grd, this=0x1e9dee0) succeeds as GSAG.
GDAL: GDALDriver::Create(WAsP,./output.map,0,0,0,Unknown,(nil))
0GDAL: GDAL_CACHEMAX = 794 MB
ERROR 6: No field defined and no Z coordinate
ERROR 1: cannot write linestring
More than 1000 errors or warnings have been reported. No more will be reported from now.
40...50...60...70...80...90...GDAL: GDALClose(./output.map, this=0x1e9dc60)
GDAL: GDALClose(./input.grd, this=0x1e9dee0)
100 - done.
Googling wasn't very helpful for this issue. Can anyone help me with this?
Thanks in advance.
Classification: Restricted
