[gdal-dev] Extracting Subsampled Mask Band from VRT Returning 1st Band Rather Than Mask Band
Patrick Young patrick.mckendree.young at gmail.com
Wed May 15 10:17:57 PDT 2019
Hi all,
I'm experiencing some strange behavior when extracting a mask band using
gdal_translate from a VRT vs the source GTiff at a reduced resolution.  I
have a 3 band, 8 bit JPEG compressed (YCbCR) RGB geotiff with an internal
no data mask and with internal overviews.  Making a VRT of this and running
gdal_translate -b mask in.vrt mask.tif
Returns the expected no data mask.
However, if I add in "-outsize 10% 0", I instead get the first band back as
the mask tif rather than the mask band.  Any -outsize setting has the same
effect.
Repeating this with the source geotiff rather than the vrt works as
expected.
Interestingly, running
gdalinfo -oo OVERVIEW_LEVEL=1 in.vrt
reports no mask flags set at all (they are reported without the -oo
option), but running on the original geotiff rather than the vrt does
report the mask flags.
Anyone have thoughts on what the VRT driver is doing?
Thanks,
Patrick
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190515/c8223aad/attachment.html>
