[gdal-dev] How to properly reorder the raster data from bottom up to top down?
Soon Hui Ngu soonhui.ngu at gmail.com
Wed May 22 17:54:39 PDT 2019
When creating a raster I set the lower-left x/y values, and asc file has
the following "header":
ncols        1731
nrows        1863
xllcorner    17548488.944545675069
yllcorner    -8069349.376163828187
dx           500.162987955558
dy           500.081943659035
Note that the raster data is going from bottom to top.
However, now it seems that I need to reorder the raster data so that my
raster data will appear from top to bottom, instead of bottom to top. In
the above case, I want the dy to assume negative value.
What is the best way to do it?
Of course I can do the thing in a manual, hard way, ie:
  using (var ds = Gdal.Open(demInputTiff, Access.GA_Update))
        var nCol = ds.RasterXSize;
        var nRow = ds.RasterYSize;
        double[] geoTransform = new double[6];
        ds.GetGeoTransform(geoTransform);
        if (geoTransform[5] < 0)
            return; //no need transformation
        geoTransform[3] += geoTransform[5] * (nRow -1);
        geoTransform[5] *= -1;
        ds.SetGeoTransform(geoTransform);
        Band band = ds.GetRasterBand(1);
        var allValues = new int[nCol * nRow];
        var noData = band.NoDataValue();
        band.ReadRaster(0, 0, nCol, nRow, allValues, nCol, nRow, 0, 0);
        //manual reordering, crude way of iterating through the array
        var allValues2 = new int[nCol * nRow];
        for (int i = 0; i < nRow; i++)
            for (int j = 0; j < nCol; j++)
                allValues2[(nRow - i - 1) * nCol + j] = allValues[i * nCol + j];
        band.WriteRaster(0, 0, nCol, nRow, allValues2, nCol, nRow, 0, 0);
        ds.FlushCache();
But is there a built-in function for this? Will converting to other formats
like AAIGRID and back and forth correct for the orientation?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190523/e679af2c/attachment.html>
