[gdal-dev] Is there a reference documentation for GDALMetadata structure?
Andrea Aime andrea.aime at geo-solutions.it
Mon May 27 08:58:34 PDT 2019
Hi Jukka,
thank you for following up. I believe that provides information for the PAM
dataset, which
is normally a sidecar containing statistical information such as
min/max/histograms.
The GDAL metadata TIFF tag instead normally contains other information,
such as scale/offset,
band names, units, and uses a XML that has a different structure.
Looking into the code there is something around here:
https://github.com/OSGeo/gdal/blob/master/gdal/frmts/gtiff/geotiff.cpp#L13726
I see explicit treatment for scale/offset and a few others, not sure if
there is anything else?
Like, if a band had a custom name, would it show up in the GDALMetadata
structure in a significant way?
>From my previous example, things like:
 <Item name="Band_1">Max Band_1</Item>.
    <Item name="Band_2">Min Band_1</Item>.
    <Item name="Band_3">Mean Band_1</Item>.
    <Item name="Band_4">SD Band_1</Item>.
    <Item name="Band_5">MASD Band_1</Item>.
    <Item name="Band_6">Valid Inputs</Item>.
are they actually used or just treated as "random strings"?
Looking at a GDALInfo output it looks like of the second, but maybe I'm
missing something:
Metadata:
  AREA_OR_POINT=Area
*  Band_1=Max Band_1*
  Band_2=Min Band_1
  Band_3=Mean Band_1
  Band_4=SD Band_1
  Band_5=MASD Band_1
  Band_6=Valid Inputs
  UNITS=m
*Band 1* Block=10x10 Type=Int32, ColorInterp=Gray
  NoData Value=-9999
  Offset: 0,   Scale:0.0001
Band 2 Block=10x10 Type=Int32, ColorInterp=Undefined
  NoData Value=-9999
Band 3 Block=10x10 Type=Int32, ColorInterp=Undefined
  NoData Value=-9999
Band 4 Block=10x10 Type=Int32, ColorInterp=Undefined
  NoData Value=-9999
Band 5 Block=10x10 Type=Int32, ColorInterp=Undefined
  NoData Value=-9999
Band 6 Block=10x10 Type=Int32, ColorInterp=Undefined
  NoData Value=-9999
Cheers
Andrea
On Mon, May 27, 2019 at 1:11 PM jratike80 <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> Perhaps here
> https://github.com/OSGeo/gdal/blob/master/gdal/gcore/gdalpamdataset.cpp
> -Jukka Rahkonen-
> geowolf wrote
> > Hi,
> > I was wondering if there is any documentation on what a GDALMetadata XML
> > structure might contain, both in terms
> > of element/attributes, and key names?
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Regards, Andrea Aime == GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime
@geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054
Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339
8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190527/b625b00f/attachment-0001.html>
