[gdal-dev] Document typo fix suggestion
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Mon May 27 17:58:30 PDT 2019
After you submit your pull request, go to your own fork and select newly
created branch. Edit button in it will append changes to the pull request.
пн, 27 мая 2019, 1:59 PM карыстальнік jratike80 <
jukka.rahkonen at maanmittauslaitos.fi> напісаў:
> Well, there is a shortcut button "Edit on GitHub" on every document page
> https://gdal.org/drivers/raster/jpeg2000.html. That't simple to use but it
> creates a new branch for each edit. I was hoping to use that easy-edit
> button for collecting all edits into one pull request. But I can do that in
> my own fork.
> -Jukka-
> Mateusz Loskot wrote
> > Simply, submit pull request.
> > Mateusz Loskot,
> > mateusz@
> > (Sent from mobile)
> > On Mon, 27 May 2019, 22:34 Rahkonen Jukka (MML), <
> > jukka.rahkonen@
> >> wrote:
> >> Hi,
> >> There are 7 occasions of ”persitant” in the GDAL documentation but I do
> >> not know how to fix them into “persistent” simply with one pull request.
> >> Advice about how to do that appreciated but I won’t get angry if someone
> >> just makes the fix.
> >> https://github.com/OSGeo/gdal/search?q=persitant&unscoped_q=persitant
> >> -Jukka Rahkonen-
> >> _______________________________________________
> >> gdal-dev mailing list
> > gdal-dev at .osgeo
> >> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> > gdal-dev at .osgeo
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190527/fd1f9b4e/attachment-0001.html>
