[gdal-dev] YAML, AppVeyor and the perks of continuous integration (Re: Willing to Pay for Help Building GDAL 3 on WIndows)
Marsh, Chris
chris.marsh at usask.ca
Tue May 28 20:06:16 PDT 2019
Sorry to hear you're having these issues. I unfortunately don't do windows dev, so I'm not really sure what to suggest build wise.
However, if you're stuck on the build proj4 step of building gdal, I would suggest you try their mailing list. I've had good luck there. Especially if they have errors in their build documentation.
https://proj4.org/community/channels.html
Cheers
Chris
On Tue, May 28, 2019 at 7:41 PM CDelancy <cdelancy at blackfangtechnologies.com<mailto:cdelancy at blackfangtechnologies.com>> wrote:
Thank you so much for the explanation, however, I fear it will not help my
problem.
You see, I cannot build GDAL3 without PROJ4 6.0, and I wouldn't want to
because important functionality would be missing. However, I cannot build
PROJ because it depends on SQLite3. I cannot build SQlite3 because there
appear to be errors in the instructions provided here:
https://sqlite.org/src/doc/trunk/README.md
"For example:
mkdir bld
cd bld
nmake /f Makefile.msc TOP=..\sqlite
nmake /f Makefile.msc sqlite3.c TOP=..\sqlite
nmake /f Makefile.msc sqlite3.dll TOP=..\sqlite
nmake /f Makefile.msc sqlite3.exe TOP=..\sqlite
nmake /f Makefile.msc test TOP=..\sqlite"
However, there is no Makefile in the bld directory that was just created, so
"fatal error U1052: file 'Makefile.msc' not found" results.
If I alter the instructions to cd back into the parent sqlite folder where a
makefile is located, I get
" tclsh ..\sqlite\tool\mkopcodec.tcl opcodes.h > opcodes.c
'tclsh' is not recognized as an internal or external command,
operable program or batch file.
NMAKE : fatal error U1077: 'tclsh' : return code '0x1'
Stop."
So I Google "tclsh" and now I'm off on in search for a program called
ActiveTcl. The quest for dependencies has no end in sight.
After installing that program, I return to trying to build sqlite3 with the
modified command dicuseed previously, the new result is:
"sqlite3.c
sqlite3.c(19711): error C2065: 'OPFLG_INITIALIZER': undeclared identifier
sqlite3.c(19711): error C2099: initializer is not a constant
sqlite3.c(76038): error C2065: 'OP_Init': undeclared identifier
sqlite3.c(76263): error C2065: 'OP_Goto': undeclared identifier
sqlite3.c(76270): error C2065: 'OP_String8': undeclared identifier
sqlite3.c(76292): error C2065: 'OP_Null': undeclared identifier
sqlite3.c(76292): error C2065: 'OP_String8': undeclared identifier
sqlite3.c(76294): error C2065: 'OP_Integer': undeclared identifier
sqlite3.c(76299): error C2065: 'OP_ResultRow': undeclared identifier
sqlite3.c(76384): error C2065: 'OP_Explain': undeclared identifier
sqlite3.c(76412): error C2065: 'OP_ParseSchema': undeclared identifier"
Lines like this continue until
"sqlite3.c(85452): fatal error C1003: error count exceeds 100; stopping
compilation
NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual
Studio\2017\Community\VC\Tools\MSVC\14.16.27023\bin\HostX86\x86\cl.EXE"' :
return code '0x2'
Stop."
So, here I am at a dead end.
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190529/522c16a9/attachment.html>
