[gdal-dev] EPSG code with vertical datum
Even Rouault
even.rouault at spatialys.com
Thu May 30 02:06:24 PDT 2019
On mercredi 29 mai 2019 20:38:02 CEST Andrew Bell wrote:
> In earlier GDAL versions I could call
> SetFromUserInput("EPSG:4326+4326");
> without error. I now get the following error:
> (Error) GDAL failure (1) SetCompoundCS() fails, vertical component is not
> VERT_CS.
> Was this a failure to detect a problem in older GDAL versions
Yes. EPSG:4326+4326 doesn't make any sense from a geodesic point of view. If
you need WGS84 as a Geographic 3D CRS, you need to use EPSG:4979
Even
http://www.spatialys.com
