[gdal-dev] Coordinate transform from coordinate reference systems with different datum error in GDAL3.0.0
Changhai Chen cchhnhk at gmail.com
Thu May 30 21:59:11 PDT 2019
Hello, I would like to ask:
When I use GDAL 2.3.3 with proj4_4.9.3, I can convert the coordinate from
EPSG:4326 to EPSG:4326+5773(egm96_15.gtx) correctly with elevation value.
But when I use GDAL 3.0.0 with proj4_6.1.0, the elevation value of
coordinate unchange (Proj.db and egm file are found). The problem occur
when I convert from WGS84 to Beijing54 too.
Function use:
              OGRCoordinateTransformation -> Transform()
Thanks.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190531/72b20d2c/attachment.html>
