[gdal-dev] gdalsrsinfo Incorrect or Inconsistent results reporting EPSG codes
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Fri Nov 1 01:10:57 PDT 2019
Please make is easier for us to help you and provide a link to such raster
file. It does not need to be your real, perhaps confidential data, a small
extract is actually much better. Just take care that if shows all the issues
that you wrote about. Meanwhile you can read
https://trac.osgeo.org/gdal/wiki/rfc73_proj6_wkt2_srsbarn and think if this
change could explain some of your observations.
-Jukka Rahkonen-
David Cakalic wrote
> Hi,
> I've been having a problem using gdal to simply read/report EPSG headers
> on rasters. I am trying to use it to verify header projection information
> is correct.
> First, I am using Windows 10.
> Rasters are Imagine .IMG format.
> Command being used is gdalsrsinfo -e {filename}
> I've tried gdal from various sources/vintages... the problem is I can only
> get it to report the proper (expected) EPSG on 2 of 6 computers... even if
> I take special care to follow same steps each time. I am also using the
> SAME EXACT image file each time.
> The projection is NAD83(2011) / UTM zone 14N.
> So I expect to see EPSG:6343
> I'm often getting EPSG:26914
> This is NAD83 / UTM zone 14N (NOT 2011)
> Or I get EPSG: -1
> The gdal install that works as expected on 2 of 6 computers is the version
> that installs on Windows along with OSgeo4w. (GDAL 2.4.1 as reported by
> "gdalsrsinfo --version" command)
> It only works if I run the gdalsrsinfo command from the C:\OSgeo4w\bin
> folder.... If I run from anywhere else I get the other results mentioned.
> Also, I've installed the same OSgeo4w on all 6 machines... and it only
> works on two.
> Other GDAL binaries for Windows I got from the gisinternals website...
> I've tried multiple versions (2.4.1, 2.4.2, 3.0....) and I'm running
> through the command shell provided with that distribution.... All getting
> different results (sometimes -1 sometimes 26914) but I simply can't
> find any consistency of WHY it is working sometimes and not others.
> One concern I have is that perhaps since GDAL is packaged with SO MANY
> programs (ESRI, Qgis, Global Mapper, etc.) that perhaps the command is
> calling incorrect libraries?
> Please... if anyone has ideas on WHY this is happening, or how to force
> the command to run from a a CLEAN environment only using the libraries I
> desire, I welcome input.
> Sincerely,
> David C.
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
