[gdal-dev] Limit on the number of files for gdalbuildvrt
Jose Gomez-Dans
jgomezdans at gmail.com
Fri Nov 1 10:21:24 PDT 2019
Dear Even,
Thanks for your help. After a bit more dredging, I am only able to repeat
my problem on a particularly mounted filesystem in an HPC facility I use.
On other systems (and even other mountpoints on that same HPC system)
things work as expected. I've taken this up with our administrators, but
just as a warning to others that it can happen and I didn't dream it!
Thanks for your very prompt reply
Jose
On Wed, 30 Oct 2019 at 16:16, Even Rouault <even.rouault at spatialys.com>
wrote:
> On mercredi 30 octobre 2019 15:52:54 CET Jose Gomez-Dans wrote:
> > Hi,
> > I'm mosaicking a large number of small tiles using the GDAL python
> bindings
> > (python 3.7, gdal 3.0.1, but also tested on 2.4.2). Code is something
> like
> > *output_fname = "/something/or/other.vrt"*
> > *fnames = ["file1.tif", ..., "fileN.tif"]*
> > *dst_ds = gdal.BuildVRT( output_fname, fnames,
> > options=gdal.BuildVRTOptions(separate=True), )*
> > *dst_ds = None*
> > This fails with lots of errors like
> > ERROR 4: fileXXX.tif: No such file or directory
> > Warning 1: Can't open fileXXX.tif. Skipping it
> gdalbuildvrt is normally cautious about non opening too many files at the
> same
> time. I can't replicate your issue with the following script
> from osgeo import gdal
> import shutil
> fnames = []
> for i in range(1024):
> dstname = 'testbuildvrt/byte%d.tif' % i
> shutil.copy('byte.tif', dstname)
> fnames.append(dstname)
> "/tmp/out.vrt",
> fnames,
> dst_ds = None
> > The aim of this is to create a VRT mosaic that can then be converted to
> > GeoTIFF.
> If you want a mosaic, you likely want separate=False.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191101/15bd20f4/attachment.html>
