[gdal-dev] gdalsrsinfo Incorrect or Inconsistent results reporting EPSG codes
Andrew C Aitchison
andrew at aitchison.me.uk
Sat Nov 2 02:34:25 PDT 2019
On Fri, 1 Nov 2019, David Cakalic wrote:
> Link below is to a sample IMG file on WeTransfer:
> https://we.tl/t-KtV9xCLaDF
> Depending on the computer, this is showing as:
> EPSG: -1
> EPSG: 26914
> EPSG: 6343
> when using gdalsrsinfo -e {image}
> or
> gdalsrsinfo -o epsg {image}
Hmm.
For that file, with gdal 2.4.2 or 2.4.3rc1 I get
EPSG:-1
but if I remove $HOME/.gdal/2.4/srs_cache/pcs.wkt.gz the next run gives
EPSG:6343
but the next run gives EPSG:-1 again as the cache file has been recreated.
With gdal 3.0.3rc1 I get
Confidence in this match: 25 %
EPSG:26914
