[gdal-dev] GDAL 3, PROJ 6.2 exportToProj4() drops Datum silently
Roger Bivand Roger.Bivand at nhh.no
Thu Nov 7 02:10:26 PST 2019
On Thu, 7 Nov 2019, Even Rouault wrote:
> On jeudi 7 novembre 2019 15:24:44 CET Nyall Dawson wrote:
>> On Wed, 30 Oct 2019 at 06:16, Even Rouault <even.rouault at spatialys.com>
> wrote:
>>>> I realise this too, but to permit legacy results to be replicated,
>>> Some legacy behaviour was just plain wrong/inaccurate. Trying to replicate
>>> it in PROJ would be heartbreaking, an extra maintaince burden, and a
>>> confusion for PROJ users because depending on the path they take, they
>>> would get different results.
>>> Not-so-random example with GDAL 2.4/PROJ 5 with GDA94 to GDA2020
>>> You get a ~1.5 metre shift to the north east as expected.
>> This thread has been bouncing around in my mind for the last week.
>> Forgive me if I'm misinterpreting the situation, but wouldn't you
>> explicitly want legacy results NOT to be reproducible in cases where
>> proj 6's more accurate transformation capabilities have affected these
>> results?
>> If a particular study isn't affected by relatively small shifts such
>> as the 1.5m shift in the GDA2020 situation, then the results should
>> remain reproducible even if this shift is corrected. But if a
>> particular study IS affected by distances of this magnitude then I'd
>> argue that it would be vital that the older proj behavior can't be
>> reproduced exactly, and accordingly the previous study/results are
>> invalidated as a direct result..!
> Are you saying that the new behaviour of ExportToProj4() shouldn't cause
> issues ? Well, that's more subtle than that. As +towgs84 terms might be
> omitted more often now, you can get differences of ~ 100 metres when dealing
> with datums dating before the GPS era. So when using GDAL 3 ExportToProj4()
> you can effectively get "wrong" results in some cases.
> The action I took for now is to document the issue with ExportToProj4():
> https://gdal.org/doxygen/
> classOGRSpatialReference.html#a271b3de4caf844135b0c61e634860f2b
The red-lined Warning is very explicit:
"Use of this function is discouraged. Its behaviour in GDAL >= 3 / PROJ >=
6 is significantly different from earlier versions. In particular +datum
will only encode WGS84, NAD27 and NAD83, and +towgs84/+nadgrids terms will
be missing most of the time. PROJ strings to encode CRS should be
considered as a a legacy solution. Using a AUTHORITY:CODE or WKT
representation is the recommended way."
I think importFromProj4() is more forgiving - is this likely to continue,
or should we move away from Proj4 anyway?
Thanks!!
Roger
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
https://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
