[gdal-dev] GPX metadata records?
Even Rouault
even.rouault at spatialys.com
Tue Nov 12 11:24:02 PST 2019
On mardi 12 novembre 2019 12:04:53 CET Gerard wrote:
> Hello,
> Is there a way to list records from the <metadata> block in GPX files (such
> as "author")? I've tried various combinations of options to ogrinfo, with
> no success. I can only seem to list various layers (tracks, track_points,
> etc.)
No, this is not handled currently by the driver. I imagine that could be
reported as dataset metadata if that were to be implemented.
That said, you can get it if you request the 'gpx' layer with the GMLAS driver
(which as not indicated by its name can deal with any XML data that comes with
a XML schema)
$ ogrinfo GMLAS:out.gpx gpx
INFO: Open of `GMLAS:out.gpx'
using driver `GMLAS' successful.
Layer name: gpx
Geometry: None
Feature Count: 1
Layer SRS WKT:
(unknown)
ogr_pkid: String (0.0) NOT NULL
version: String (0.0) NOT NULL DEFAULT '1.1'
creator: String (0.0) NOT NULL
metadata_name: String (0.0)
metadata_desc: String (0.0)
metadata_author_name: String (0.0)
metadata_author_email_id: String (0.0)
metadata_author_email_domain: String (0.0)
metadata_author_link_href: String (0.0)
metadata_author_link_text: String (0.0)
metadata_author_link_type: String (0.0)
metadata_copyright_author: String (0.0)
metadata_copyright_year: Integer (0.0)
metadata_copyright_license: String (0.0)
metadata_time: DateTime (0.0)
metadata_keywords: String (0.0)
metadata_bounds_minlat: Real (0.0)
metadata_bounds_minlon: Real (0.0)
metadata_bounds_maxlat: Real (0.0)
metadata_bounds_maxlon: Real (0.0)
metadata_extensions: String (0.0)
OGRFeature(gpx):1
ogr_pkid (String) = B92FB579C2748DDC57A1F15E41EBDBC3_gpx_1
version (String) = 1.1
creator (String) = GDAL 3.1.0dev-dacda90-dirty
metadata_author_name (String) = x
Even
http://www.spatialys.com
