[gdal-dev] Schema support in OAPIF and GeoJSON
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Wed Nov 13 08:18:32 PST 2019
GeoJSON from OGC API Features service may contain schema or reference to schema and OAPIF driver resolves it. Does the plain GeoJSON driver have the same support? If not, how about to add the support, possibly with an open option to read the schema from a local file? Otherwise it can happen that reading GeoJSON from a server would give different schema than reading the same GeoJSON from a disk if data does not contain all the attributes from the schema.
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191113/aacf065b/attachment.html>
