[gdal-dev] ogr2ogr PDF
paul.malm at lfv.se paul.malm at lfv.se
Fri Nov 15 00:31:02 PST 2019
Stephen,
thanks for responding!
I've tried this:
PEN(c:#FF00FF,w:3pt,p:"3pt 3pt")
PEN(c:#FF00FF,w:3pt,p:3pt 3pt)
PEN(p:"3pt 3pt",c:#FF00FF,w:3pt)
PEN(p:3pt 3pt,c:#FF00FF,w:3pt)
PEN(c:#FF00FF, p:"3pt 3pt",w:3pt)
PEN(c:#FF00FF, p:3pt 3pt,w:3pt)
But I'm getting the same solid line. Width and color are ok.
I have also tried to use: PEN(c:#FF00FF,id:ogr-pen-4,w:3pt)
And I'm only getting the same solid line....
I'm using GDAL 2.4.1, released 2019/03/15
As I understand the PDF driver should handle line patterns.
/Paul
-----Ursprungligt meddelande-----
Från: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] För Stephen Woodbridge
Skickat: den 14 november 2019 16:44
Till: gdal-dev at lists.osgeo.org
Ämne: Re: [gdal-dev] ogr2ogr PDF
Paul,
Your issue might be one of scale. You have specified units in px try
changing it to pt. (units (g, px, pt, mm, cm, in))
See: https://gdal.org/user/ogr_feature_style.html#ogr-feature-style
You can also try named pens like:
Here is the current list of OGR pen ids (this could grow over time):
    ogr-pen-0: solid (the default when no id is provided)
    ogr-pen-1: null pen (invisible)
    ogr-pen-2: dash
    ogr-pen-3: short-dash
    ogr-pen-4: long-dash
    ogr-pen-5: dot line
    ogr-pen-6: dash-dot line
    ogr-pen-7: dash-dot-dot line
    ogr-pen-8: alternate-line (sets every other pixel)
System-specific ids are very likely to be meaningful only to that
specific system that created them. The ids should start with the
system’s name, followed by a dash (-), followed by whatever information
is meaningful to that system (a number, a name, a filename, etc.).
e.g. “mapinfo-5”, or “mysoft-lines.sym-123”, or “othersystems-funnyline”
System-specific ids are allowed in order to prevent loss of information
when dealing with data from systems that store line patterns in external
files or that have their own pre-defined set of line styles (for
instance, to do a MapInfo MIF to TAB translation without any loss.)
Examples:
PEN(c:#00FF00,id:”ogr-pen-0”) - simple solid line
PEN(c:#00FF00,id:”mapinfo-5,ogr -pen-7”) - corresponds to MapInfo’s Pen
#5, and a system that can’t understand MapInfo pens falls back on the
default “ogr-pen-7” pen (dot-dot line).
-Steve W
On 11/14/2019 2:18 AM, paul.malm at lfv.se wrote:
> Thanks for responding Jukka!
> I'm getting real irritated of myself for not getting such a simple thing to work with such grate tools.
> I have now tried with:
> PEN(c:#FF00FF,w:3px,p:"3px 3px")
> PEN(c:#FF00FF,w:3px,p:3px 3px)
> PEN(p:"3px 3px",c:#FF00FF,w:3px)
> PEN(p:3px 3px,c:#FF00FF,w:3px)
> PEN(c:#FF00FF, p:"3px 3px",w:3px)
> PEN(c:#FF00FF, p:3px 3px,w:3px)
> /Paul
> Från: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] För jratike80
> Skickat: den 13 november 2019 16:35
> Hi,
> What is supported is documented in a table in
> https://gdal.org/drivers/raster/pdf.html. For PEN only these options are
> supported: color (c); width (w); dash pattern (p).
> So why, you know, nobody has implemented it yet. Meanwhile you can do
> something with dash pattern, or edit the PDF with some PDF editor.
> -Jukka Rahkonen-
> paul.malm wrote
>> Hi,
>> I’m now setting attribute OGR_STYLE in my postGis db for a testlayer
>> (line)
>> I’m now setting attribute OGR_STYLE in my postgis db for a test layer
>> (LineString):
>> … SET \"OGR_STYLE\"= 'PEN(c:#FF3333,id:ogr-pen-4,w:1px)'
>> Does anyone know why the pen symbol (id) is ignored when exporting the
>> PDF, it’s always a solid line?
>> Color and width is ok.
>> I’ve tried to draw a ogr-symbol together with a point layer and it worked
>> like a charm.
>> Kind regards,
>> Paul
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
