[gdal-dev] Compile problems gdal3.0.2 against proj6
Mateusz Loskot mateusz at loskot.net
Tue Nov 19 05:03:17 PST 2019
On Tue, 19 Nov 2019 at 13:41, Andreas Neumann <a.neumann at carto.net> wrote:
> Note that two versions of proj are on my system: the old version in /usr and the new version in /usr/local - with the configure_param I am pointing it to the new version.
Then, check also what ./configure reports as PROJ version found.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
