[gdal-dev] gdalwarp overhead on linux but not on windows
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Tue Nov 19 14:20:34 PST 2019
I have been told that Docker has overhead with everything, with these
numbers as evidence:
ubuntu at t:/etc$ time gdalinfo --version
GDAL 2.2.3, released 2017/11/20
real 0m0.030s
user 0m0.017s
sys 0m0.013s
ubuntu at t:/etc$ time docker exec -it 742a044b8ef1 gdalinfo --version
GDAL 3.1.0dev-19f34295c8c310b6ecb27d2d7aa7ac0a2a2a3d9f, released 2019/11/05
real 0m0.386s
user 0m0.023s
sys 0m0.030s
-Jukka Rahkonen-
alex-6 wrote
> Hi guys,
> I've been playing quite a lot with "wrapper_GDALWarpDestName" and a .net
> core wrapper (https://github.com/MaxRev-Dev/gdal.netcore/).
> Everything is running fine, I'm quite happy to see the same behavior on
> windows and linux. Sometimes linux is faster for reading and writing
> raster, this is great ! .NET Core is (now) a very good option for cross
> platform dev. Anyway...
> When calling wrapper_GDALWarpDestName, I'm experiencing an overhead of
> 350 to 500 ms on linux that I don't see at all on Windows.
> To narrow down the issue, I tried many warp options (-multi; -wo
> NUM_THREADS=4; -wm 2000), output drivers (MEM, VRT, NWT_GRD), input file
> format (MEM, VRT, NWT_GRD), input and output projections. I also checked
> Gdal.GetCacheUsed(), Gdal.HasThreadSupport() and Gdal.GetCacheMax(),
> same values between linux and windows. Nothing helps.
> Even with VRT format output, this overhead is present which proves this
> is not related to processing. I bet for some sort of initialization of
> the warp algorithm with file reading... because 400 ms is far from
> nothing. But I'm wondering why this is occurring for every single call
> on linux and not on windows... Any option I could try ? My next step is
> to profile the linux process but I'm not good at that so any help there
> would be great too.
> OS (version): Windows 10 (1903)
> Docker:
> Server: Docker Engine - Community
> Engine:
> Version: 19.03.2
> API version: 1.40 (minimum version 1.12)
> Go version: go1.12.8
> Git commit: 6a30dfc
> Built: Thu Aug 29 05:32:21 2019
> OS/Arch: linux/amd64
> Experimental: false
> Linux in docker file: debian 9
> (mcr.microsoft.com/dotnet/core/runtime:2.2-stretch-slim)
> Package version (core): [e.g. 3.0.1.25]
> Package version (runtime windows): [e.g. 3.0.1.25]
> Package version (runtime linux): [e.g. 3.0.1.2]
> This is the kind of code I'm running:
> namespace GdalCoreTest
> class Program
> static void Main(string[] args)
> GdalBase.ConfigureAll();
> Console.WriteLine("GDAL configured");
> Console.WriteLine(string.Join('\n',
> "GDAL Version: " + Gdal.VersionInfo("RELEASE_NAME"),
> "GDAL INFO: " + Gdal.VersionInfo("")));
> WarpFile();
> WarpFile();
> WarpFile();
> public static void WarpFile()
> Stopwatch sw = new Stopwatch();
> int sizeX = 1024, sizeY = 1024;
> var driver = Gdal.GetDriverByName("MEM");
> string path = $"/vsimem/test.mem";
> string vrtFilePath = null;
> using(Dataset ds = driver.Create(path, sizeX, sizeY, 1,
> DataType.GDT_UInt32, new string[0]))
> try
> //create a grid
> ds.SetGeoTransform(new double[]{0, 30, 0, 0, 0, -30});
> var ttt = new SpatialReference(null);
> ttt.ImportFromProj4("+proj=longlat +datum=WGS84");
> ttt.ExportToWkt(out string latLongWkt, new string[0]);
> ds.SetProjection(latLongWkt);
> //write data in the buffer
> int[] buffer = new int[sizeX * sizeY];
> for (int x = 0; x < sizeX; x++)
> for (int y = 0; y < sizeY; y++)
> buffer[y * sizeX + x] = x + y;
> ds.GetRasterBand(1).WriteRaster(0, 0, sizeX, sizeY, buffer, sizeX,
> sizeY, 0, 0);
> //Prepare for warping
> IntPtr[] ptr = {Dataset.getCPtr(ds).Handle};
> GCHandle gcHandle = GCHandle.Alloc(ptr, GCHandleType.Pinned);
> var dss = new
> SWIGTYPE_p_p_GDALDatasetShadow(gcHandle.AddrOfPinnedObject(), false,
> null);
> vrtFilePath = $"/vsimem/tile.vrt";
> //Warp
> sw.Start();
> using (Dataset dst = Gdal.wrapper_GDALWarpDestName(vrtFilePath, 1,
> dss, new GDALWarpAppOptions(new[]{"-of", "VRT" }), null,null))
> sw.Stop();
> finally
> Gdal.Unlink(path);
> Gdal.Unlink(vrtFilePath);
> Console.Out.WriteLine($"Warp duration = {sw.ElapsedTicks} ticks
> ({sw.ElapsedMilliseconds} ms).");
> This is the output I'm getting on windows:
> GDAL configured
> GDAL Version: 3.0.1
> GDAL INFO: GDAL 3.0.1, released 2019/06/28
> Warp duration = 221267 ticks (22 ms).
> Warp duration = 133395 ticks (13 ms).
> Warp duration = 155402 ticks (15 ms).
> This is the output I'm getting on docker/linux:
> GDAL configured
> GDAL Version: 3.0.1
> Warp duration = 395911725 ticks (395 ms).
> Warp duration = 368923383 ticks (368 ms).
> Warp duration = 373055090 ticks (373 ms).
> Thanks,
> Alex.
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
