[gdal-dev] Gdal_grid and lake bathymetry
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Thu Nov 21 08:21:47 PST 2019
Hi Joaquim,
GMT surface probably has all the features that I need. I followed the tutorial and managed to run surface demos, now I just need to learn how to use my own data as input.
-Jukka-
-----Alkuperäinen viesti-----
Lähettäjä: Joaquim Manuel Freire Luís <jluis at ualg.pt>
Lähetetty: keskiviikko 20. marraskuuta 2019 0.30
Vastaanottaja: Even Rouault <even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org
Kopio: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
Aihe: RE: [gdal-dev] Gdal_grid and lake bathymetry
The GMT surface program has two (well 3) options that are of interest to this.
-One, the -Lu<upper> that serves to limit the upper value in the interpolated grid
-The other is the option -D that lets you set a soft-breakline (your shorelines). Soft-breaklines are lines whose vertex end up in the grid nodes closest to them. They are called "soft" in contraposition to the hard-breaklines that do not let the interpolation algorithm go across them. Imagine interpolation a terrain with vertical cliffs. Unfortunately that -D option is missing on the html man page but is described on the surface on line help.
-Finally, option -M lets you mask the outside lakes region
https://docs.generic-mapping-tools.org/latest/surface.html
Joaquim
-----Original Message-----
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Even Rouault
Sent: Tuesday, November 19, 2019 10:13 PM
To: gdal-dev at lists.osgeo.org
Cc: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
Subject: Re: [gdal-dev] Gdal_grid and lake bathymetry
On mardi 19 novembre 2019 22:03:29 CET Rahkonen Jukka (MML) wrote:
> Hi,
> I would like to get some hints about using gdal_grid or some other
> utility for lake bathymetry. What I have is typically rather sparse
> point data of depths and the shoreline that includes the islands as in
> the attached image. The shoreline and all the area that is not lake
> basin should have the altitude of zero in the resulting DEM. It means
> that interpolation should not overshoot across the shoreline over the dry land.
> Gdal_grid seems to miss an option for handling the shoreline so I made
> a test by converting the vertices of the polygon rings into depth
> points. I also filled area around the lake with a gridded points of
> zero altitude but the method feels stupid and tedious and the result
> was not so fine when it comes to keep the shoreline and land area near it totally flat.
Postprocessing with gdalwarp -cutline to set to zero non-lake areas ?
Spatialys - Geospatial professional services http://www.spatialys.com _______________________________________________
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
