[gdal-dev] Export a geotiff to netcdf in lat lon coordinates
Tony L.
tony_lst3 at yahoo.com
Mon Nov 25 12:20:29 PST 2019
Hello Paul,Thanks for your reply, I tried the command you suggested but the resulting file doesn't seem to plot correctly. Any suggestion?
Tony
Try this:
gdal_translate -of netCDF -a_srs +proj=longlat N_197901_concentration_v3.0.tif out.nc
Paul
On 2019-11-22 1:24 PM, Tony L. wrote:
> Hello
> I'm quite new with gdal and would like to use is to rewrite a geotiff of
> NSIDC sea ice concentration from geotiff in polar stereographic
> projection into a netcdf in Lon Lat coordinates
> The file is located here: N_197901_concentration_v3.0.tif
> <https://www.dropbox.com/s/bkqt6qgyhpr7vjk/N_197901_concentration_v3.0.tif?dl=0>
> Shared with Dropbox
> I was able to transform the file into a netcdf file using gdal_translate:
> gdal_translate -of netCDF N_197901_concentration_v3.0.tif out.nc
> But I'm still trying to figure out how to translate this into Lon Lat
> coordinates (probably using gdalwarp)
> Any help would be really appreciated!
> Tony
gdal-dev mailing list
gdal-dev at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191125/463ece7b/attachment.html>
