[gdal-dev] ogr2ogr (I)LIKE not caseINsensitive
Even Rouault even.rouault at spatialys.com
Thu Nov 28 07:58:17 PST 2019
On jeudi 28 novembre 2019 16:42:19 CET Jan Heckman wrote:
> Hi Even, all,
> Thanks for the fast and helpful response!
> So, if I need this shortly, I should compile a slightly modified version?
> I can't see myself giving a true solution to the backward compatibility
> issue ;)
> My problem here is not large.
> The main advantage of caseinsensitive is a compact and accurate query, I
> was used to seeing if I could just omit the first (capital or not)
> character.
Try the changeset at https://github.com/OSGeo/gdal/pull/2065
> But I ran into a case where this produced unwanted results and cmdline
> gave ERROR 1: Destination buffer too small.
Can you share how to reproduce that? That should be fixed
Even
http://www.spatialys.com
