[gdal-dev] ERROR: Too many connections: max 64
Shane Carey
careyshan at gmail.com
Thu Nov 28 12:44:39 PST 2019
Or is it better to do the processing on shapefiles?
Le gach dea ghui,
*Shane Carey*
*GIS and Data Solutions Consultant*
On Thu, Nov 28, 2019 at 8:40 PM Shane Carey <careyshan at gmail.com> wrote:
> After processing, is there a way to release the wal and shm files? I'm on
> qgis3.4.
> Thanks Even
> Le gach dea ghui,
> *Shane Carey*
> On Thu, Nov 28, 2019 at 8:37 PM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> On jeudi 28 novembre 2019 20:19:10 CET Shane Carey wrote:
>> > Hi,
>> > I'm doing some processing with Pyqgis and after processing, the file
>> > remains locked and eventually I get:
>> All I can say is that this error messages comes from Spatialite that can
>> only
>> handle 64 connections in a process at most. I did a fix (don't remember
>> when,
>> but must be included in QGIS 3.4) in the QGIS OGR provider to be able to
>> open
>> GeoPackage datasets (since the OGR GeoPackage driver enables Spatialite
>> on
>> them) that has many layers (so that they share the same connection). Not
>> sure
>> about the specificities of your use case.
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191128/6375a8e7/attachment.html>
