[gdal-dev] Issue decoding some jp2 files with rasterio/JP2OpenJPEG
Javier Becerra Elcinto javier at panoimagen.com
Tue Oct 1 08:54:37 PDT 2019
Yesterday I submitted an issue at rasterio github's repository
(https://github.com/mapbox/rasterio/issues/1790) regarding an error
message while decoding some jpeg 2000 files. You can check there for the
full details, the main part of the error message is:
|ERROR 1: skip: segment too long (2563) with max (687) for codeblock 0
(p=1301, b=0, r=7, c=0) ERROR 1: Failed to decode. ERROR 1: Failed to
decode tile 1/1 ERROR 1: opj_decode() failed ||ERROR 1: ov185090_201700_c025u89x10c24n.jp2, band 1: IReadBlock failed
at X offset 0, Y offset 0: opj_decode() failed|
sgillies suggested me to post on this list, to see if someone has
already found this issue. If you can take a look, in the issue
description there is a link with two 'offending' jp2 files and one that
is working properly for me.
As stated on the issue, a QGis 3.6.2 install on Windows opens these
files properly, although there are 3 jpeg2000 drivers listed when I run
'gdalinfo --formats' on that machine (vs only the JP2OpenJPEG driver
only for the failing rasterio code).
Thanks for your time!
Regards,
Javier
/Dr. Ing. de Telecomunicación/
/Director Técnico/
*PANOimagen, s.l.*
*Dirección:*
Calle Baltasar Gracián Nº13 - Oficina 3
26006 Logroño, La Rioja (Spain)
*Teléfono:*
+34 941 01 99 88 móvil:+34 680 257 524
*Web:*
www.panoimagen.com <http://www.panoimagen.com/>
*e-mail:*javier at panoimagen.com <mailto:javier at panoimagen.com>
<https://twitter.com/panoimagen?lang=es> facebook
<https://www.facebook.com/panoimagen/>
<https://es.linkedin.com/company/panoimagen> github
<https://github.com/PANOimagen>
De acuerdo con lo establecido por el Reglamento (UE) 2016/679, en
materia de Protección de datos, le informamos que el Responsable del
Tratamiento de sus datos es PANOIMAGEN, S.L. Utilizamos sus datos para
prestarle los servicios que nos ha solicitado así como enviarle
comunicaciones profesionales que sean de su interés.  Legitimados en el
interés legítimo del responsable. No se cederán sus datos a terceros
salvo obligación legal. Así mismo, le informamos que tiene derecho a
acceder, rectificar y suprimir los datos, así como otros derechos,
indicados en la información adicional, que puede ejercer en
info at panoimagen.com <mailto:info at panoimagen.com>Este mensaje y sus
archivos adjuntos van dirigidos exclusivamente a su destinatario,
pudiendo contener información confidencial sometida a secreto
profesional. No está permitida su reproducción o distribución sin
nuestra autorización expresa. Si usted no es el destinatario final por
favor elimínelo e infórmenos por esta vía.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191001/44f33ab7/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191001/44f33ab7/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191001/44f33ab7/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191001/44f33ab7/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191001/44f33ab7/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191001/44f33ab7/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191001/44f33ab7/attachment-0011.png>
