[gdal-dev] vrt guidance: 31 band classified raster
mhw-at-yg
matt.wilkie at gov.yk.ca
Fri Oct 4 15:36:43 PDT 2019
> You could also potentially use a raster attribute table. See
> GDALRasterAttributeTable in https://gdal.org/drivers/raster/vrt.html
Yeah, loose is right. ;-) This is what I think I've puzzled out:
<http://osgeo-org.1560.x6.nabble.com/file/t192661/2019-10-04_15_29_23-Book1_-_Excel.png>
would be expressed as:
Type 2 means it's a string (GFT_String)
Usage 2 means this is the name of the class (GFU_Name)
Type 0 means a non-decimal number (GFT_Integer)
Usage 5 means use for pixels matching this value from the intersecting row
(GFU_MinMax)
Am I on the right track?
-Matt
-Matt
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
