[gdal-dev] procedure for .kml to .xlsx conversion with geometry included
Ravi Teja Krishna Wuyyuru ravitejakrishna.w at zohocorp.com
Tue Oct 8 07:17:13 PDT 2019
Hello GDAL Team,
We would like to use ogr2ogr file format conversion in our product using java bindings. I have read in gdal website that for xlsx conversion there is no geometry support but may use ogr vrt capabilities for that.
can you please elaborate the procedure i need to follow so i can convert .kml files directly to .xlsx format which has geometry included.
Note: i have already built gdal with expat support so upon trying to convert from .kml to .xlsx iam getting file which misses Geometry Column.
Thanks in advance.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191008/0999bbee/attachment.html>
