[gdal-dev] python GDAL issue
Brad Hards bradh at frogmouth.net
Thu Oct 10 13:47:47 PDT 2019
Can you make the NITF file available? Can you at least post the relevant
part of the BANDSB TRE from the file?
Brad
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Edson, Adam
Robert
Sent: Friday, 11 October 2019 6:09 AM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] python GDAL issue
I am trying to parse a TRE in a NITF following the spec found here
(https://nsgreg.nga.mil/doc/view?i=4829
<https://nsgreg.nga.mil/doc/view?i=4829&month=10&day=10&year=2019>
&month=10&day=10&year=2019). Specifically, I am having trouble with the
BANDSB TRE with the EXISTENCE_MASK field. It is supposed to be an unsigned
int that can be used as bit flags for data following after it. I am
currently getting garbage at this location from the gdal.getMetadata('TRE')
call. Any help would be appreciated.
Adam
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191011/bdab4ed1/attachment.html>
