[gdal-dev] Syntax for translation to ERMapper Raster with options
Richard Lane rjllane at gmail.com
Mon Oct 14 12:23:58 PDT 2019
I am trying to convert some SRTM raster data from Arc/Info ASCII Grid
format to ERMapper ERS grid format and program gdal_translate is not doing
what I was hoping that it would do. I imagine that I have the wrong syntax.
Any help would be greatly appreciated.
The default output when I used the following command was a
Signed32BitInteger grid with no projection, datum or units information.
gdal_translate -of ERS cut_s30e090.asc cut_s30e090.ers
To specify output as Signed16BitInteger with Projection = GEODETIC, Datum =
GDA94, and Units = Degrees, I issued the following command
gdal_translate -of ERS -co “PROJ=GEODETIC” -co “DATUM=GDA94” -co
“UNITS=Degrees” -ot Int16 -projwin_srs EPSG:4283 cut_s30e120.asc
cut_s30e120.ers
What am I doing wrong? I am very new to GDAL, so my errors could be very,
very basic, but I came up with the above by reading the documentation as
carefully as I could.
Thank-you ... Richard
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191015/f8897c86/attachment.html>
