[gdal-dev] 503 Errors when accessing Public Datasets on Google Cloud Storage with automatic auth
Christoph Paulik cpaulik at vandersat.com
Wed Oct 16 08:38:29 PDT 2019
The thing is that one request works fine in any case.
But google seems to rate limit on the public bucket in the following cases:
- no authentication (/vsicurl/ driver)
- authentication with automatic detection by gdal that it is running on a
GCE VM.
but not when using the explicit authentication with
GS_ACCESS_KEY_ID/GS_SECRET_ACCESS_KEY
Christoph
On Wed, 16 Oct 2019 at 17:31, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> did you try with Google gsutil tool ?
> Anyway as it is a public resource that doesn't require any signing, you
> could
> just use
> /vsicurl/
> https://storage.googleapis.com/gcp-public-data-sentinel-2/tiles/29/T/
> NE/S2B_MSIL1C_20170719T112119_N0205_R037_T29TNE_20170719T112511.SAFE/GRANULE/
> L1C_T29TNE_A001922_20170719T112511/IMG_DATA/T29TNE_20170719T112119_B01.jp2
> <https://storage.googleapis.com/gcp-public-data-sentinel-2/tiles/29/T/NE/S2B_MSIL1C_20170719T112119_N0205_R037_T29TNE_20170719T112511.SAFE/GRANULE/L1C_T29TNE_A001922_20170719T112511/IMG_DATA/T29TNE_20170719T112119_B01.jp2>
> Even
> > Hi,
> > When doing a few requests to the Sentinel 2 bucket of Google (
> > https://cloud.google.com/storage/docs/public-datasets/sentinel-2) we
> have
> > been getting 503 Responses when using the automatic authentication. See
> the
> > end of this email for the full output.
> > This behavior goes away when using e.g. the
> > GS_ACCESS_KEY_ID/GS_SECRET_ACCESS_KEY authentication method.
> > The Service account this machine is running with has "Full Access to All
> > Cloud APIs"
> > Not sure if this is a gdal problem or actually a google internal issue
> > since accessing our own buckets works fine.
> > Best,
> > Christoph
> > Output:
> > export CPL_DEBUG=ON
> > gdalinfo
> /vsigs/gcp-public-data-sentinel-2/tiles/29/T/NE/S2B_MSIL1C_20170719T112119_N
> > HTTP: Fetch(
> http://metadata.google.internal/computeMetadata/v1/instance/service-accounts
> > /default/token )
> > HTTP: libcurl/7.65.3 OpenSSL/1.1.1c zlib/1.2.5 libssh2/1.8.2
> > HTTP: GDAL was built against curl 7.64.1, but is running against 7.65.3.
> > HTTP: These HTTP headers were set: Metadata-Flavor: Google
> > GOA2: Refresh Token Response:
> > {"access_token":"REMOVED IN
> EMAIL","expires_in":2877,"token_type":"Bearer"}
> > GOA2: Access Token : 'REMOVED IN EMAIL'
> > GS: Using GCE inherited permissions
> > GS: <html><head><meta http-equiv="content-type" content="text/html;
> > charset=utf-8"/><title>Sorry...</title><style> body { font-family:
> verdana,
> > arial, sans-serif; background-color: #fff; color: #000;
> > }</style></head><body><div><table><tr><td><b><font face=sans-serif
> > size=10><font color=#4285f4>G</font><font color=#ea4335>o</font><font
> > color=#fbbc05>o</font><font color=#4285f4>g</font><font
> > color=#34a853>l</font><font color=#ea4335>e</font></font></b></td><td
> > style="text-align: left; vertical-align: bottom; padding-bottom: 15px;
> > width: 50%"><div style="border-bottom: 1px solid
> > #dfdfdf;">Sorry...</div></td></tr></table></div><div style="margin-left:
> > 4em;"><h1>We're sorry...</h1><p>... but your computer or network may be
> > sending automated queries. To protect our users, we can't process your
> > request right now.</p></div><div style="margin-left: 4em;">See <a href="
> > https://support.google.com/websearch/answer/86640">Google Help</a> for
> more
> > information.<br/><br/></div><div style="text-align: center; border-top:
> 1px
> > solid #dfdfdf;"><a href="https://www.google.com">Google
> > Home</a></div></body></html>
> > VSICURL: GetFileSize(
> > 9TNE_A001922_20170719T112511/IMG_DATA/T29TNE_20170719T112119_B01.jp2)=0
> > response_code=503
> verdana,
> more
> 1px
> > ERROR 11: HTTP response code: 503
> > gdalinfo failed - unable to open
> '/vsigs/gcp-public-data-sentinel-2/tiles/29/T/NE/S2B_MSIL1C_20170719T112119_
> > 12511/IMG_DATA/T29TNE_20170719T112119_B01.jp2'.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
*Christoph Paulik* // Head of Infrastructure
VanderSat // Satellite observed water data. Globally. Daily.
Wilhelminastraat 43a, 2011 VK, Haarlem (NL), The Netherlands
<https://maps.google.com/?q=Wilhelminastraat+43a,+2011+VK,+Haarlem+(NL),+The+Netherlands&entry=gmail&source=g>
*M*  +31 6 18271928 *W*  www.vandersat.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191016/efb31994/attachment-0001.html>
