[gdal-dev] Documenting build requirements (e.g. ODBC)
Thomas Gratier osgeo.mailinglist at gmail.com
Mon Oct 21 09:08:36 PDT 2019
In my opinion, although there are not explanations, Travis build files are
a good help to sort out building issues dependencies.
https://github.com/OSGeo/gdal/tree/master/gdal/ci/travis
Mentioning them somewhere could help
Regards
Thomas Gratier
Le dim. 20 oct. 2019 à 22:27, Mateusz Loskot <mateusz at loskot.net> a écrit :
> On Sun, 20 Oct 2019 at 19:31, Jeff McKenna
> <jmckenna at gatewaygeomatics.com> wrote:
> > > On lundi 30 septembre 2019 11:21:16 CEST Mateusz Loskot wrote:
> > >> I'm a bit lost where build requirements are supposed
> > >> to be documented now. They used to be described
> > >> on the Wiki, e.g. https://trac.osgeo.org/gdal/wiki/BuildingOnUnix
> > >> or driver-specific ones https://trac.osgeo.org/gdal/wiki/ECW
> > The wiki worked really well for that, and over the years we compiled
> > quite a list of build steps for drivers and platforms
> > (https://trac.osgeo.org/gdal/wiki/BuildHints).  I'd suggest we continue
> > to use the wiki method (meaning now we transition to the Github wiki),
> > so we don't have any funnels where someone needs to approve or
> > disapprove of a change to the official website or repository.
> I don't have anything against the wiki but a wiki is supposed to be
> complementary to existing docs.
> Even suggested to recover the "Compiled by default" column
> from the table in the old docs. On reflection, I don't think that
> will solve problem I'm calling in this thread - what are the build
> requirements of GDAL and features in GDAL.
> IMO, there should be
> https://gdal.org/building/
> https://gdal.org/building/requirements
> https://gdal.org/building/unix
> https://gdal.org/building/windows
> where https://gdal.org/building/requirements  lists common dependencies
> similarly to https://pdal.io/development/compilation/dependencies.html
> e.g. it lists ODBC and describes briefly that it is required by drivers A,
> B, C,
> that on Unix one can use unixODBC or iODBC; that on Windows it comes
> with native Windows SDK.
> Similarly for libcurl, proj, and any other general purpose dependency of
> GDAL.
> > The argument sometimes used against a wiki is that it is not managed,
> > but this is exactly why the Buildhints wiki was allowed to thrive.
> Official build procedure with requirements listed is  one thing.
> Build hints, workarounds and troubleshooting is a different thing.
> IMO, the former should be reviewed, curated and up to date
> while the latter is a perfect fit for community-written wiki
> that can rot...
> > There of course will still be one hurdle, requiring to have a Github
> > account, but besides that the wiki should thrive there for years to come.
> Similar hurdle (requirement of an account) applies to OSGeo infrastructure.
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191021/aa9c27e9/attachment-0001.html>
