[gdal-dev] OGR Python API to Load Esri JSON
Even Rouault
even.rouault at spatialys.com
Thu Oct 24 01:50:08 PDT 2019
On jeudi 24 octobre 2019 14:19:15 CEST Nyall Dawson wrote:
> On Thu, 24 Oct 2019 at 06:10, Even Rouault <even.rouault at spatialys.com>
wrote:
> > Hi Jeremy,
> > > Is there a OGR Python API to load Esri JSON into an OGR geometry object,
> > > much like CreateGeometryFromJson?
> > If you update to latest master, yes:
> > https://github.com/OSGeo/gdal/commit/5dadb24e3b9a1364ad3792ca63cd9312925b8
> > 601
> I don't suppose the reverse function is available, is it?
No, ESRI Json is read-only
Even
http://www.spatialys.com
