[gdal-dev] converting AAIGrid to SRTM
Bryan Fields
Bryan at bryanfields.net
Fri Oct 25 02:40:51 PDT 2019
On 10/25/19 5:33 AM, Even Rouault wrote:
>> Is there a way to trim this to 36001x36001 before converting it to the
>> 1201x1201 tiles?
> the -srcwin switch of gdal_translate:
> https://gdal.org/programs/gdal_translate.html
> like -srcwin 11 11 36001 36001
Thanks, I'll give it a try later today.
>> When I run this conversion, I need an exact 1201x1201 image. I'm also not
>> sure how to verify this is correct. My concern is if I'm a pixel off that
>> is up to 90m, and now it would appear I'm 23 pixels off, or up to 2.07km.
> the SRTMHGT driver should emit a warning if the extent of the input dataset
> has not the expected extent.
It doesn't :)
I get everything looking like it's working, then a row of final output tiles
of 23 x 1201 SRTM files.
I'll try it later I'm coming of a maintenance window and getting ready for bed.
Bryan Fields
727-409-1194 - Voice
http://bryanfields.net
