[gdal-dev]  cannot open PDS files anymore
    Andrea Battisti
    battisti at actgate.com
    Mon Oct 28 09:50:29 PDT 2019
Looks like GDAL cannot open raster data in PDS format anymore.
[tested against master few minutes ago, maybe a regression?]
gdalinfo LDEM_60N_60M_FLOAT.LBL
ERROR 4: `LDEM_60N_60M_FLOAT.LBL' not recognized as a supported file format.
gdalinfo failed - unable to open 'LDEM_60N_60M_FLOAT.LBL'.
Some more info:
-) it was working on 2.2.2 on the same data.
-) maybe it is size related ?, seems to work on smaller files, for
example LDEM_45S_400M_FLOAT.LBL works, from the same set [*]
Any idea on what can cause this?
[*] Data files can be downloaded from:
http://imbrium.mit.edu/DATA/LOLA_GDR/POLAR/FLOAT_IMG/
Andrea Battisti
Computer Science Engineer
