[gdal-dev] GDAL 3, PROJ 6.2 exportToProj4() drops Datum silently
Even Rouault even.rouault at spatialys.com
Tue Oct 29 15:33:42 PDT 2019
On mercredi 30 octobre 2019 09:22:11 CET Michael Sumner wrote:
> Great discussion, thanks to both of you.  I have a question.
> I wonder how we ought to specify a projection that we desire, I work in
> contexts where 1.5m or even 1.5 km is not an unreasonable level of
> precision, and we get a lot of value out of specifying local projections
> (at ocean basin scale) in LAEA, LCC, STERE and others  (OMERC is especially
> good for hermisphere-scale migrating birds, very custom and not related to
> human activities) - PROJ strings are obviously an easy to specify the
> family and centre point of the projection, and we have a lot of workflows
> (computer and human) for this. The datum is a bit irrelevant a lot of the
> time but we always include it and try to explain it to users.
> Are we expected to express a full WKT or WKT2 string for this?   I know we
> can write wrappers in some language, but there doesn't seem to be a culture
> around crafting custom projections that I can latch onto. Usually I see
> people looking for an EPSG code for their region, and as often as not they
> end up using UTM because "it's a projection" and no authority has ever done
> a survey in their part of the Southern Ocean and published it with EPSG.
> Is something like the gdaltransform pipelining syntax the most concise we
> can aim for, or do we somehow cache our own local EPSG-like codes?
I'm a bit extreme when I say "don't use PROJ strings", but otherwise people
don't get it :-) So yes if you don't care about datum transformations, don't
use unusual axis orders, you might still use them. They won't disappear in a
foreseable future.
The GDAL OGRSpatialReference class has a number of helper methods to help you
build your own custom CRS, like SetLAEA(), SetLCC(), etc. and SetGeogCS()
The PROJJSON notation might also be slightly easier to work with than WKT2 (it
is completely equivalent to it, just using a more standard encoding):
example at https://github.com/OSGeo/PROJ/pull/1547
Schema at https://proj.org/schemas/v0.1/projjson.schema.json
Even
http://www.spatialys.com
