[gdal-dev] Fwd: Gdal - multipolygon - geometry errors instead holes
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Thu Oct 31 01:14:03 PDT 2019
It seems to me that the geometry is valid but for some reason the shapefile
reader reads it wrong. It is not trivial to investigate the issue and
developers tend to be busy. Meanwhile you can ask that ArcMap user to save
data into GeoPackage so you can make a test with that.
-Jukka Rahkonen-
Pepa Beneš wrote
> Hi Tobias,
> please, could You help me, with originall question? Is the geometry valid
> or it isn't? If it is not, why?
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
