[gdal-dev] Motion: approve GDAL 2.4.3RC1 and 3.0.2RC1 as final
Even Rouault
even.rouault at spatialys.com
Thu Oct 31 04:08:58 PDT 2019
A few issues [1] have been fixed since in those branches since the RCs, but
they predated 2.4.0, so those new releases are not worse than their previous
x.y.0, so I move to
+1 Even
[1]
- PDS: fix opening of datasets with BSQ organization (or single band), where
one band is larger than 2 GB (2.3 regression)
- IRIS: make identification more restrictive to avoid false-positive
identification of raw binary formats such as ENVI (fixes #1961)
- OGRLinearRing::isPointOnRingBoundary(): fix incomplete test that could
falsely return true if the point was aligned with a segment, but not between
the nodes. Impact correct reconstruction of holes in shapefile driver
http://www.spatialys.com
