[gdal-dev] Motion: approve GDAL 2.4.3RC1 and 3.0.2RC1 as final
Mateusz Loskot
mateusz at loskot.net
Thu Oct 31 09:55:02 PDT 2019
+1
Thanks Even!
Mateusz
On Thu, 31 Oct 2019 at 17:46, Howard Butler <howard at hobu.co> wrote:
> +1
> Howard
> On Oct 31, 2019, at 9:39 AM, Daniel Morissette <dmorissette at mapgears.com> wrote:
> +1
> Daniel
> On 2019-10-31 07:08, Even Rouault wrote:
> Hi,
> A few issues [1] have been fixed since in those branches since the RCs, but
> they predated 2.4.0, so those new releases are not worse than their previous
> x.y.0, so I move to
> +1 Even
> [1]
> - PDS: fix opening of datasets with BSQ organization (or single band), where
> one band is larger than 2 GB (2.3 regression)
> - IRIS: make identification more restrictive to avoid false-positive
> identification of raw binary formats such as ENVI (fixes #1961)
> - OGRLinearRing::isPointOnRingBoundary(): fix incomplete test that could
> falsely return true if the point was aligned with a segment, but not between
> the nodes. Impact correct reconstruction of holes in shapefile driver
> Daniel Morissette
> Mapgears Inc
> T: +1 418-696-5056 #201
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Mateusz Loskot, http://mateusz.loskot.net
