[gdal-dev] Question on gdal_contour and limiting the range of contours generated.
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Thu Oct 31 11:11:38 PDT 2019
One more suggestion, have you tried the -fl option "Name one or more “fixed
levels” to extract"? Requires  some writing but only once if you save the
list into an optfile https://gdal.org/programs/raster_common_options.html. I
haven't tried the option with hundreds of fixed levels, though.
-Jukka-
Jukka,
Thanks! After trying shapefile and exceeding 2GB, I switched to postgres
and deleted the elevation as you suggested.
I'm working with a global relief model the includes both elevation and
bathymetry depth over the whole world at about 15 arc-sec/pixel. I
generates a lot of contour lines between 8,000 and -10,000 meters, I was
think it would be handy to gdal_dem had a few more options to control
the range and direction of contour generation.
I also have played with gdal_calc to create an elevation and bathymetry
only files.
Thanks, I think I have workarounds for the moment.
-Steve W
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
