[gdal-dev] NetCDF and ESA Probav issue with corner coordimates
Ivan Lucena
ivan.lucena at outlook.com
Thu Oct 31 14:06:37 PDT 2019
Hi Folks,
I Downloaded NetCDF files from http://land.copernicus.eu/global/products/ndvi and I am having problems with the GeoTransform that the driver is getting.
The image extents, as you can see in following gdalinfo report, goes beyond the -180 and +180 longitude degrees (half resolution, half pixel) but that's OK according to page 27 in the PDF documentation: PROBAV-Products_User_Manual_v1.3.pdf<https://earth.esa.int/documents/700255/1929094/PROBAV-Products_User_Manual_v1.3.pdf/fd5e30f4-5305-4d41-86aa-fab7b9568251>
But if I open that image on QGIS and overlay a vector (GADM from gadm.org) or any other global layer it is clear that -180x80 should be in the upper left corner of the image, not In the center. There is a half pixel missing on the left and bottom of the image. This in in Fiji:
[cid:fe6be096-c2db-42a9-a1c0-15358ccf71bb]
The gdalinfo report shows that the crs:GeoTransform is -180.0000000000 0.0029761905 0.0 80.0000000000 0.0 -0.0029761905 but it seems like the driver decided to take that to as center of the pixel based. Looking at the NetCDF source I can see that there this possibility exists.
Of course, I am not waiting for a solution. I just used gdal_translate "- a_ullr" and fix that into the target format. It takes centuries to converted that image to geotiff. But I am concerned that others might get in trouble because of that.
I tried to contact the data provider but did not received an answer yet.
Does anybody has experience with that dataset and/or NetCDF that can help figure out what is going on. It is a bug in the driver or an issue with the data.
Thanks,
Ivan
Here is the gdalinfo report:
Don't worry about the warnings in regards to the pixel values. It is fine.
$ gdalinfo netcdf:c_gls_NDVI300_201910110000_GLOBE_PROBAV_V1.0.1.nc --debug on
GDAL_netCDF: driver detected file type=5, libnetcdf detected type=3
Warning 1: NetCDF driver detected file type=5, but libnetcdf detected type=3
GDAL_netCDF: setting file type to 3, was 5
GDAL_netCDF: dim_count = 2
GDAL_netCDF: var_count = 4
GDAL_netCDF: NCDFGetAttr unsupported type 7 for attribute _FillValue
GDAL_netCDF: NCDFGetAttr unsupported type 7 for attribute missing_value
GDAL_netCDF: NCDFGetAttr unsupported type 7 for attribute flag_values
GDAL_netCDF: NCDFGetAttr unsupported type 7 for attribute valid_range
GDAL_netCDF:
SetProjectionFromVar( 3)
GDAL_netCDF: got grid_mapping crs
GDAL_netCDF: bIsGdalFile=1 bIsGdalCfFile=0 bBottomUp=0
GDAL_netCDF: got spheroid from CF: (6378137.000000 , 298.257224)
GDAL_netCDF: set bBottomUp = 0 from Y axis
GDAL_netCDF: setting WKT from CF
GDAL_netCDF: SetProjection, WKT = GEOGCS["unknown",DATUM["unknown",SPHEROID["Spheroid",6378137,298.257223563]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]]]
GDAL_netCDF: xdim: 120960 nSpacingBegin: 3 nSpacingMiddle: 3 nSpacingLast: 3
GDAL_netCDF: ydim: 47040 nSpacingBegin: -3 nSpacingMiddle: -3 nSpacingLast: -3
GDAL_netCDF: setting WKT from GDAL
GDAL_netCDF: SetProjection, WKT = GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]]
GDAL_netCDF: SetGeoTransform(-180.001488,0.002976,0.000000,80.001488,0.000000,-0.002976)
GDAL_netCDF: bGotGeogCS=1 bGotCfSRS=1 bGotCfGT=1 bGotGdalSRS=1 bGotGdalGT=0
Warning 1: Unsupported netCDF datatype (7), treat as Float32.
GDAL_netCDF: netcdf type=5 gdal type=6 signedByte=1
GDAL_netCDF: got add_offset=-0.07999999821186066, status=0
GDAL_netCDF: got scale_factor=0.004000000189989805, status=0
GDAL: GDALOpen(netcdf:c_gls_NDVI300_201910110000_GLOBE_PROBAV_V1.0.1.nc, this=00000219E2D291F0) succeeds as netCDF.
Driver: netCDF/Network Common Data Format
GDAL: GDALDefaultOverviews::OverviewScan()
Files: none associated
Size is 120960, 47040
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
Origin = (-180.001488095238102,80.001488095238088)
Pixel Size = (0.002976190476204,-0.002976190476190)
Metadata:
crs#GeoTransform=-180.0000000000 0.0029761905 0.0 80.0000000000 0.0 -0.0029761905
crs#grid_mapping_name=latitude_longitude
crs#inverse_flattening=298.257223563
crs#longitude_of_prime_meridian=0
crs#long_name=coordinate reference system
crs#semi_major_axis=6378137
crs#spatial_ref=GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]]
crs#_CoordinateAxisTypes=GeoX GeoY
crs#_CoordinateTransformType=Projection
lat#axis=Y
lat#DIMENSION_LABELS=lat
lat#long_name=latitude
lat#standard_name=latitude
lat#units=degrees_north
lat#_CoordinateAxisType=Lat
lon#axis=X
lon#DIMENSION_LABELS=lon
lon#long_name=longitude
lon#standard_name=longitude
lon#units=degrees_east
lon#_CoordinateAxisType=Lon
NC_GLOBAL#archive_facility=VITO
NC_GLOBAL#Conventions=CF-1.6
NC_GLOBAL#copyright=Copernicus Service information 2019
NC_GLOBAL#history=Processing line NDVI: 2019-10-22
NC_GLOBAL#identifier=urn:cgls:global:ndvi300_v1_333m:NDVI300_201910110000_GLOBE_PROBAV_V1.0.1
NC_GLOBAL#institution=VITO NV
NC_GLOBAL#long_name=Normalized Difference Vegetation Index
NC_GLOBAL#orbit_type=LEO
NC_GLOBAL#parent_identifier=urn:cgls:global:ndvi300_v1_333m
NC_GLOBAL#platform=Proba-V
NC_GLOBAL#processing_level=L3
NC_GLOBAL#processing_mode=Near Real Time
NC_GLOBAL#product_version=V1.0.1
NC_GLOBAL#references=http://land.copernicus.eu/global/products/ndvi
NC_GLOBAL#sensor=VEGETATION
NC_GLOBAL#source=Derived from EO satellite imagery
NC_GLOBAL#time_coverage_end=2019-10-20T23:59:59Z
NC_GLOBAL#time_coverage_start=2019-10-11T00:00:00Z
NC_GLOBAL#title=10-daily Normalized Difference Vegetation Index 333M: GLOBE 2019-10-11T00:00:00Z
NDVI#add_offset=-0.079999998
NDVI#flag_meanings=Missing cloud snow sea background
NDVI#flag_values={}
NDVI#grid_mapping=crs
NDVI#long_name=Normalized Difference Vegetation Index 333M
NDVI#missing_value=
NDVI#scale_factor=0.0040000002
NDVI#standard_name=normalized_difference_vegetation_index
NDVI#units=
NDVI#valid_range={}
NDVI#_FillValue=
OGRCT: PROJ >= 4.8.0 features enabled
OGRCT: Using locale-safe proj version
OGRCT: Source: +proj=longlat +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +no_defs
OGRCT: Target: +proj=longlat +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +no_defs
Corner Coordinates:
Upper Left (-180.0014881, 80.0014881) (180d 0' 5.36"W, 80d 0' 5.36"N)
Lower Left (-180.0014881, -59.9985119) (180d 0' 5.36"W, 59d59'54.64"S)
Upper Right ( 179.9985119, 80.0014881) (179d59'54.64"E, 80d 0' 5.36"N)
Lower Right ( 179.9985119, -59.9985119) (179d59'54.64"E, 59d59'54.64"S)
Center ( -0.0014881, 10.0014881) ( 0d 0' 5.36"W, 10d 0' 5.36"N)
Band 1 Block=120960x1 Type=Float32, ColorInterp=Undefined
NoData Value=0
Offset: -0.0799999982118607, Scale:0.00400000018998981
Metadata:
flag_values={}
grid_mapping=crs
missing_value=
NETCDF_VARNAME=NDVI
units=
valid_range={}
_FillValue=
GDAL: GDALClose(netcdf:c_gls_NDVI300_201910110000_GLOBE_PROBAV_V1.0.1.nc, this=00000219E2D291F0)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191031/1f561c0b/attachment-0001.html>
Type: image/png
Desc: image.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191031/1f561c0b/attachment-0001.png>
