[gdal-dev] ogr2ogr
lars.schylberg at blixtmail.se lars.schylberg at blixtmail.se
Wed Sep 4 06:22:11 PDT 2019
Hi Paul,
if You do: gdalinfo --formats | grep AERONAVFAA
does your format show up?
I could be that You have to make your own build to have AERONAVFAA included.
It doesn't show up in my debian build.
/Lars
4 september 2019 kl. 14:46, paul.malm at lfv.se (mailto:paul.malm at lfv.se) skrev:
	I don’t know if this is the correct forum.
	I would like to fonvert a aeronavFAA obstacle file to the Esri shape format.
	From all the information I can find on internet I think this should be correct:
	C:Program FilesGDAL>ogr2ogr -f "ESRI Shapefile" c:tempFAAdof13_ga C:DownloadsFAA_DOF13-GA.DAT
	This is the error message I get:
	FAILURE:
	Unable to open datasource `C:UsersanpaumalDownloadsshapefilerFAA_DOF13-GA.DAT' with the following drivers.
	-> `netCDF'
	-> `PCIDSK'
	-> `PDS4'
	-> `JP2OpenJPEG'
	-> `PDF'
	-> `MBTiles'
	-> `EEDA'
	-> `DB2ODBC'
	-> `ESRI Shapefile'
	-> `MapInfo File'
	-> `UK .NTF'
	-> `OGR_SDTS'
	-> `S57'
	-> `DGN'
	-> `OGR_VRT'
	-> `REC'
	-> `Memory'
	-> `BNA'
	-> `CSV'
	-> `NAS'
	-> `GML'
	-> `GPX'
	-> `LIBKML'
	-> `KML'
	-> `GeoJSON'
	-> `GeoJSONSeq'
	-> `ESRIJSON'
	-> `TopoJSON'
	-> `Interlis 1'
	-> `Interlis 2'
	-> `OGR_GMT'
	-> `GPKG'
	-> `SQLite'
	-> `ODBC'
	-> `WAsP'
	-> `PGeo'
	-> `MSSQLSpatial'
	-> `PostgreSQL'
	-> `MySQL'
	-> `OpenFileGDB'
	-> `XPlane'
	-> `DXF'
	-> `CAD'
	-> `Geoconcept'
	-> `GeoRSS'
	-> `GPSTrackMaker'
	-> `VFK'
	-> `PGDUMP'
	-> `OSM'
	-> `GPSBabel'
	-> `SUA'
	-> `OpenAir'
	-> `OGR_PDS'
	-> `WFS'
	-> `WFS3'
	-> `HTF'
	-> `AeronavFAA'
	-> `Geomedia'
	-> `EDIGEO'
	-> `GFT'
	-> `SVG'
	-> `CouchDB'
	-> `Cloudant'
	-> `Idrisi'
	-> `ARCGEN'
	-> `SEGUKOOA'
	-> `SEGY'
	-> `ODS'
	-> `XLSX'
	-> `ElasticSearch'
	-> `Walk'
	-> `Carto'
	-> `SXF'
	-> `Selafin'
	-> `JML'
	-> `PLSCENES'
	-> `CSW'
	-> `VDV'
	-> `GMLAS'
	-> `MVT'
	-> `TIGER'
	-> `AVCBin'
	-> `AVCE00'
	-> `NGW'
	-> `HTTP'
	I can see that the driver AeronavFAA is tested, since it is listed above, what am I doing wrong?
	Kind regards,
	Paul
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190904/ecfe64c6/attachment.html>
