[gdal-dev] gdal_translate is slow
Denis Rykov rykovd at gmail.com
Wed Sep 4 08:26:14 PDT 2019
Thanks for quick reply, I've uploaded grib file here:
https://transfer.sh/5JCVX/download.grib
On Wed, Sep 4, 2019 at 5:04 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> On mercredi 4 septembre 2019 08:50:09 CEST Sean Gillies wrote:
> > Hi Denis,
> > rio-convert lacks some of the features of gdal_translate (advanced
> metadata
> > translation, statistics, &c) and it may be that the cost of those
> features
> > is being especially felt in the GRIB case.
> For a plain gdal_translate like that, shouldn't matter
> > In fact, the core of
> > gdal_translate has some GRIB-specific code that rasterio does not use:
> https://github.com/OSGeo/gdal/blob/master/gdal/apps/gdal_translate_lib.cpp#L
> > 1763-L1782 .
> That part of the code shouldn't be called at all for a plain
> gdal_translate,
> and even, it shouldn't impact performance
> Without the exact dataset to reproduce, hard to know what happens.
> An hypothesis might be that the dataset has many bands, and as the GTiff
> driver will produce a pixel-interleaved file, it might need to switch
> frequently between source GRIB bands, but there's a limited cache for
> those
> bands. If rio convert proceeds band by band, this might be more beneficial
> here. Blind and likely wrong guess...
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190904/1e6f276b/attachment.html>
