[gdal-dev] OGR FileGDB driver: 'OBJECTID' not recognised as an available field
    Tamas Szekeres
    szekerest at gmail.com
    Thu Sep  5 13:51:49 PDT 2019
I'm not sure if bForwardWhereToSourceLayer should not be set in this case,
since the special field FID in pszWHEREIn has already been replaced.
Or the OpenFileGDB driver should indeed expose OBJECTID as a column
according to #4253
Best regards,
Tamas
 Even Rouault <even.rouault at spatialys.com> ezt írta (időpont: 2019. szept.
5., Cs, 13:13):
> On mercredi 4 septembre 2019 22:13:40 CEST Tamas Szekeres wrote:
> > Hi,
> > It looks like  the sql queries with -dialect "OGRSQL" doesn't seem to
> work
> > as expected. When I specify the FID in the where clause, it doesn't
> filter
> > anything. The same query is also described as a solution in the following
> > ticket https://trac.osgeo.org/gdal/ticket/4253 but I doubt if that
> works at
> > all.
> > The code causing this problem is fairly generic (ogr_gensql.cpp)
> > if( psSelectInfo->where_expr && pszDialect != nullptr &&
> >             EQUAL(pszDialect, "OGRSQL") )
> >             int nMinIndexForSpecialField =
> > poSrcLayer->GetLayerDefn()->GetFieldCount();
> >             bForwardWhereToSourceLayer =
> > !OGRGenSQLResultsLayerHasSpecialField
> >                             (psSelectInfo->where_expr,
> > nMinIndexForSpecialField);
> >         if (bForwardWhereToSourceLayer)
> >             pszWHERE = CPLStrdup(pszWHEREIn);
> >         else
> >             pszWHERE = nullptr;
> > In the "where" expression, the FID field is thanslated to OBJECTID and it
> > is now treated as a special field, therefore the "where" expression is
> not
> > being passed to the driver.
> > I'm also unsure if that is a correct action to omit passing "where" to
> the
> > layer instead of providing an error message.
> Actually the where isn't completely discarded. It is set on the
> OGRGenSQLResultsLayer per
>     if( !bForwardWhereToSourceLayer )
>         OGRGenSQLResultsLayer::SetAttributeFilter( pszWHEREIn );
> around line 492
> The issue is that the GenSQL layer has no FID column set, and thus this
> filter
> fails. One could potentially set the FID Column name on it from the source
> layer, but that wouldn't be really appropriate in the case of JOIN. That
> said
> I see a poDstFeat->SetFID( poSrcFeat->GetFID() ); at line 1332 of
> TranslateFeature(), so...
> (there might have been other fixes since #4253 that have made this case
> broken)
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190905/46fe485a/attachment.html>
