[gdal-dev] Calculations with uint16 rasters
    Alexandre Neto
    senhor.neto at gmail.com
    Wed Sep 18 02:59:18 PDT 2019
hi Even,
If you think it's better to keep it that way, let's leave it as it is. :-)
I will definitely try to add that as a hint to the docs. Not sure if that's
how you guys work, but I have created an issue for that taks:
https://github.com/OSGeo/gdal/issues/1848
Thanks for the fast answer.
Alex
On Wed, Sep 18, 2019 at 10:19 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> On mercredi 18 septembre 2019 10:00:51 CEST Alexandre Neto wrote:
> > Hi,
> > I am new to this list so sorry if this has ever been asked or discussed.
> > I am using two sentinel bands in gdal_calc. they are in jp2 format and
> > uint16. I was surprised that subtracting one for the other (A - B) was
> > giving me strange results.
> > gdal_calc.py --calc "(A-B)" --format GTiff --type Float32 -A
> /home/aneto/ARSI/data/S2A_MSIL2A_20170513T172301_N9999_R012_T14TPP_20190912T
> 155528.SAFE/GRANULE/L2A_T14TPP_A009876_20170513T172257/IMG_DATA/R10m/T14TPP_
> > 20170513T172301_B08_10m.jp2 --A_band 1 -B
> > 20170513T172301_B04_10m.jp2 --B_band 1 --outfile
> /tmp/processing_90d61cb0e2a74784a9fcf4b11f9fd7dc/9945d3aec4a749d98f2a3d14694
> > abe16/OUTPUT.tif
> > The result only returns positive integers, and the integers scale seems
> > shifted to accommodate the negative values to something above 0.
> > Strangely the fix comes by multiplying the values by 0.1. So (A*1.0 -
> > B*0.1) works as expected.
> > Is this a known issue? Is it the expected behavior?
> It's kind of expected given how NumPy works, but a lot of people get into
> this
> trap.
> Instead of multiplying by 1, you can also do A.astype(numpy.float32). This
> should be marginally faster.
> This is very much the same as doing in C/C++
> unsigned int A = 1;
> unsigned int B = 2;
> float C = A - B;
> C will be 4294967296 (initialy I used 'unsigned short' for A and B, and I
> got
> -1 as the result, because in C/C++, when there's an arithmetic operation
> on
> types smaller than int, the operand get promoted to int first, which is
> signed)
> We could possibly modify gdal_calc to grab the input raster on the
> specified
> output type, but I'm not completely sure this is a good idea, as there
> could
> be use cases where people would want the initial data type to be preserved.
> But feel free to suggest a hint in the documentation of
> https://gdal.org/programs/gdal_calc.html
> I'd suggest both a note in the doc of the --type switch, and add an
> example
> similar to yours at the end.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190918/9d452de0/attachment.html>
