[gdal-dev] ESRI FileGDB driver causing issues with Postgis	build due to packaged libstdc++
    Even Rouault
    even.rouault at spatialys.com
    Thu Sep 26 15:46:39 PDT 2019
On jeudi 26 septembre 2019 15:44:11 CEST Andrew Joseph wrote:
> should I delete the libstdc++.so and libstdc++.so.6.0.2.1 files as well?
> (sorry I'm unfamiliar with with C/C++)
Yes any file with libstdc++ in its name (just in /usr/local/FileGDB_API/lib )
http://www.spatialys.com
