[gdal-dev] ogrinfo : strange behaviour ?
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Fri Sep 27 05:28:21 PDT 2019
With GDAL 2.4.2 from OSGeo4W I had to bypass the certificate check to avoid
error "ERROR 1: SSL certificate problem: unable to get local issuer
certificate".
This gives data:
ogrinfo GEOJSON:https://france-geojson.gregoiredavid.fr/repo/regions.geojson
-al -so --config GDAL_HTTP_UNSAFESSL YES --debug on
With GDAL 3.0.1dev the certificate was accepted without bypass. I don't know
what has been fixed but it must be something certificate related.
-Jukka Rahkonen-
Blaise de Carné wrote
> Hello there !
> I've got a strange behaviour with gdal 2.4.2 :
>> ogrinfo https://france-geojson.gregoiredavid.fr/repo/regions.geojson
>> INFO: Open of `
> https://france-geojson.gregoiredavid.fr/repo/regions.geojson'
> using driver `GeoJSON' successful.
> Right, that's ok. But now :
>> ogrinfo GeoJSON:
>> FAILURE:
> Unable to open datasource `GeoJSON:
> https://france-geojson.gregoiredavid.fr/repo/regions.geojson' with the
> following drivers [...]
> Expected : same result, as with gdal 2.4.0
> --debug ON give me :
> GNM: GNMRegisterAllInternal
> GNM: RegisterGNMFile
> GNM: RegisterGNMdatabase
> HTTP: Fetch(https://france-geojson.gregoiredavid.fr/repo/regions.geojson)
> HTTP: libcurl/7.52.1 GnuTLS/3.6.9 zlib/1.2.8 libidn2/2.2.0 libpsl/0.17.0
> (+libidn2/0.16) libssh2/1.7.0 nghttp2/1.18.1 librtmp/2.3
> HTTP: These HTTP headers were set: Accept: text/plain, application/json
> ERROR 6: Update from remote service not supported
> FAILURE:
> following drivers.
> Have a nice day !
> Blaise
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
