[gdal-dev] Importing OSM: closed ways being skipped
Even Rouault even.rouault at spatialys.com
Fri Sep 27 14:28:53 PDT 2019
> The amended code looks like this:
>         ds = gdal.OpenEx(input_pbfname, gdal.OF_VECTOR)
>         nly = ds.GetLayerCount()
>         ds.ResetReading()
>         for ily in (0,1,2,4,3):
>             layer = ds.GetLayerByIndex(ily)
>             layer.ResetReading()
>             feat = layer.GetNextFeature()
>             while feat is not None:
>                  # do stuff with feat
This is not the proper way of doing layer interleaved reading. It might work
by chance on your particular dataset, but not in the general case. See
https://gdal.org/drivers/vector/osm.html#interleaved-reading
With recent GDAL versions, you might also use ds.GetNextFeature()
See https://github.com/OSGeo/gdal/blob/master/autotest/ogr/ogr_osm.py#L702
http://www.spatialys.com
