[gdal-dev] Packages on PyPi vs. Ubuntu/Fedora
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Mon Sep 30 05:02:55 PDT 2019
Hi Even,
And thanks for your swift reply.
If I install Python bindings like:
pip3 install gdal==2.4.2
installation works fine.
However, if I then install nansat:
pip3 install nansat
then pip3 tries to re-install GDALs python bindings for GDAL version 3 (which fails).
So, users are caught up in package-mismatches and I was wondering if it would be possible to have something like:
import subprocess
gdal_version = None
try:
gdal_version = subprocess.check_output(['gdal-config', '--version']).decode('utf8').strip('\n')
except:
print('Warning: Could not identify GDAL version, using default!')
if not gdal_version:
gdal_version = '3.0.0'
in setup.py for the Python bindings.
But maybe that messes too much with how pip is supposed to work...?
Cheers
Stefan
-----Original Message-----
Sent: mandag 30. september 2019 12:35
To: gdal-dev at lists.osgeo.org
Cc: Stefan Blumentrath <Stefan.Blumentrath at nina.no>
Subject: Re: [gdal-dev] Packages on PyPi vs. Ubuntu/Fedora
On lundi 30 septembre 2019 08:19:41 CEST Stefan Blumentrath wrote:
> Hi gdal-devs,
> GDAL on PyPi is already at version 3, while e.g. Ubuntu and Fedora
> still ship GDAL 2. Thus, downstream Python packages that do not
> particularly specify to depend on GDAL <3 fail to build via pip3,
> cause pip3 tires to install Python bindings for GDAL 3, which is missing on the system.
> Would it be possible for the GDAL package on PyPi to check for and
> pick up the (latest) GDAL version installed in the system?
I don't think that's something GDAL has control over. This is a pure pip behaviour. Users should definitely specify the version of GDAL for which they have the native library installed.
Even
Spatialys - Geospatial professional services http://www.spatialys.com
