[gdal-dev] Accessing DES in NITF through GDAL
Even Rouault
even.rouault at spatialys.com
Thu Apr 2 08:03:32 PDT 2020
Adam,
> I am working with NITF data. How are Data Extension Segments (DES) accessed
> through GDAL?
Complicated topic.
TRE stored in DES are reported in the TRE and xml:TRE metadata domains.
For generic DES extraction, you need to build GDAL with the ESRI_BUILD macro
enabled, and then they should be reported as Base64 encoded content in the
NITF_DES metadata domain, but I haven't tried such builds recently.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200402/e171eeea/attachment.html>
