[gdal-dev] Polygonize output inverted
Richard
r.l.morley82 at gmail.com
Sun Apr 5 05:47:27 PDT 2020
Hi there,
I’m having an issue trying to use the GDAL Polygonize feature in QGIS.
My aim is to clip out or mask the background of some hyperspectral data of some diseased Cocoa leaves for my research masters project. My background up until this project with GIS has been fairly rudimentary GUI use of ArcGIS and QGIS.
My attempted workflow involves using a k-means classifier to classify the HSI raster files, then convert to vector to edit out background and use result to clip out or mask the background of my HSI data. However, when I run GDAL Polygonize the output is inverted above the input raster.
I’ve tried adding a coordinate projection to the input raster data prior to converting, but this didn’t work.
The input file info is:
CRS
EPSG:4326 - WGS 84 - Geographic
Extent
0.0000000000000000,-696.0000000000000000 : 520.0000000000000000,0.0000000000000000
Unit
degrees
Width
520
Height
696
Data type
Byte - Eight bit unsigned integer
GDAL Driver
GTiff
And the output is:
Storage
ESRI Shapefile
Comment
Encoding
macintosh
Geometry
Polygon (MultiPolygon)
CRS
Extent
0.0000000000000000,0.0000000000000000 : 520.0000000000000000,696.0000000000000000
Unit
degrees
Feature count
761
The log from processing reads:
2020-04-05T13:21:51 INFO gdal_polygonize.py /Users/user/Documents/qgis_test/kmns/c1a_kmns.tif /Users/user/Documents/qgis_test/c1a_vctr.shp -b 1 -f "ESRI Shapefile" c1a_vctr Class
2020-04-05T13:21:51 INFO GDAL execution console output
0...10...20...30...40...50...60...70...80...90...Creating output /Users/user/Documents/qgis_test/c1a_vctr.shp of format ESRI Shapefile.
100 - done.
I’ve read a few forum posts on some similar issues, but solutions seem aimed at raster projections. It’s clear the extents are inversed, but I can’t figure out how to change them.
Any input would be gratefully received,
Richard
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200405/b3ff790d/attachment.html>
